Problem libsdl2 on i.MX6DL
domenicoacri
Hello everyone,
i have a problem with the libsdl2 on the processor i.MX6DL.
I'm trying to render an image through these libraries and use hardware accelerators.
This does not seem to work, the only solution seems to be the use of software accelerators.
I'm using x11 and libraries libsdl2_2.0.5.
The libsdl2 are configuration with the following features :
--enable-video-opengl
--enable-video-x11
Best Regards
Domenico Acri
Labels (4)
joanxie
refer to the other customer feedback, can support libsdl, not libsdl2, maybe you can try to use libsdl, and check if your local.conf include this.
