We have developed a software framework that targets the SDK and will be using several chips including the K20F due to none of the other processors meeting our needs and would like to be able to not change the common framework.
Hi Michael:
Unfortunately, currently no plan to support K60F/K20F.
Where can we get some documentation on how to create an SDK that is compatible with MCUExpresso and its tools? I had a port to the SDK2.0 tools that worked with KDS but it does not work with MCUExpresso.
Here is one document MCUXpresso IDE User Guide.pdf, it seems relevant to your requirement.
It is under your MCUXpresso installation folder.
Chapter 6 Creating New Projects using installed SDK part support.
