How can I reset two cores if the SWT0 or SWT1 time-out?
congtaoxu
      About MPC5775K microcontroller.Now,I can reset the Z4 core if the SWT0 time-out and reset the Z7 core if the SWT1 time-out.Now,I want to reset Z4 and Z7 if SWT0 or SWT1 time-out. That means I can reset all the cores if any one of them runs away.Is there any way to achieve it?
Respect
        Tao,
davidtosenovjan
Hi, you need to configure FCCU module for reset fault reaction to SWT event as shown below:
Here you may find a guide for FCCU configuration:
https://www.nxp.com/docs/en/application-note/AN5284.pdf
Hope it helps
