How to save all FLASH
program to my computer become a file xx.s19 or xx.abs thank you,I need all memory
in>SAVE 4000..7FFF DUMP.s19
Error: bad digit in decimal numbe
why is that?
Solved! Go to Solution.
You have to use 0x as prefix for hexadecimal numbers:
SAVE 0x4000..0x7FFF DUMP.s19
I hope this helps,
Erich
I hope this helps,
Erich
Hi Erich
Thank you for answering my question!I have solved the problem
But there was an error when save the third paragraphError: while reading memory from 30C000
Reason: memory not defined in given range
How to solve?
