The LPCXpresso IDE for Linux available to download on NXP page is no compatible with raspbian, but Eclipse IDE can run on raspbian.
Hi David Zamudio,
Maybe you can try the MCUXpresso IDE whose link is below.
MCUXpresso IDE|Eclipse-based Integrated Development Environment (IDE)|NXP
TIC
Hello jeremyzhou, thanks for the answer
I'll copy past the terminal output after to run Linux MCUXpresso Installer
dpkg: error al procesar el archivo mcuxpressoide-10.2.0_759.x86_64.deb (--install):
la arquitectura del paquete (amd64) no corresponde con la del sistema (armhf)
Did you know spanish? Its easy :smileyhappy:
Someone tell me about to compile mi object and upload it to the lpc's flash by serial. I'm looking about it right now
