How disable semihosting in MCUXpresso?
matheus_pinto1
I want use OpenSDA like a USB-UART converter to comunicate with PC.
This was a simple task when used PE and KDS.
However trying do this in MCUXpresso with FRDM-KL25Z and KSDK2, a semihosting message had appears in IDE console, and the program debbuger goes to HardFault_Handler.
I want to know how disable semihosting in MCUXpresso to use normally UART0 through OpenSDA.
danielchen
Hi Matheus:
Please uncheck the semihost option when you import the projects
next uncheck the redirect SDK printf to C library printf. You can redirect printf to UART
danielchen
Hi Matheus:
knovinger
How do you change these settings after the project has been created?
victorjimenez
Hello Kevin,
Please see the image below.
Select your project on the Project Explorer > Miscellaneous > Quick Settings > SDK Debug console > UART console
Victor.
knovinger
Thank you for the response.
I also found https://community.nxp.com/docs/DOC-334074
matheus_pinto1
Thanks Daniel!
