port control register base address
Question asked by lin on May 24, 2018
Latest reply on May 25, 2018 by lin
I used S32k144 chip and used S32 design studio IDE. I tried to configure portA and portc's pin out. found that portc c can be controlled by code. but port A pin did not work.  I debugged it, found that Port A PDOR is updated by code, but the real pin output status did not get change. so I want to check port A pin control register. but I did not know the port A pin control register base address. do you know what's the problem for port A did not work issue. and what 's the base address of port A pin control register?
