Production Programming support for LS1046A
josephwhite
I am looking for third party support for programming LS1046A NOR flash via JTAG using a lower cost and more friendly   automation than Code Warrior suite
Any Suggestions?
My alternative so far:
Segger - Not available yet but is planned
PE Micro - Has anyone used? Looking at this now.
yipingwang
Hello Joseph White,
Previously we have the solution to use CodeWarrior TAP to work with gdb to do the custom board bringing up, please refer to How to debug LS1046A using CodeWarrior TAP and gdb? .
However there is no initialization file for LS1046(ARM processor) in the demo package, you need to create the target initialization file by yourself.
TIC
