does bootloader source code exist for k82
gokulnath12345
does bootloader source code exist for k82 freedom board.
Firstly I could not make blhost to work with frdm k82 board, but board is working fine with internal flash codes.
I could not use bootloader code in rom to work.
please tell me the required steps to make bootloader code to work and hence blhost application also to work with.
I always get Ping failed  response, whenever i give get property commands.
thanks
gokul.
miduo
Maybe you would like to have a look at this post:https://community.nxp.com/message/1009610I hope it helpful.
Fang
