How to use KMS with a resolver feedback
athulyavarier
Is it possible to use kinetis motor suite with resolver feedback?
Thanks and Regards
Athulya varier
Hexmoto controls.
linestream-adam
Senior Contributor I
Yes. There are customers who are doing this today.
You need to replace the QEI block with an equivalent block that handles converting the resolver inputs into an electrical angle for the motor that varies between -1 and 1 for each pole pair. Where 0 is directly aligned with the pole.
