FTM output compare MCUXpresso SDK_2.x_FRDM-K66F working?
Question asked by wygonski on May 19, 2018
Latest reply on May 25, 2018 by wygonski
I am using the MCUXpresso SDK_2.x_FRDM-K66F example for FTM output compare project:  "frdmk66f_driver_examples_ftm_ftm_output_compare."  The FTM output toggles as expected but when I change the FTM compare value, the timing does not change.   I've stepped through the FTM_SetupOutputCompare library function.   I'm running on the FRDM-K66F eval board.
Changing the compare value should change the frequency of the output, why doesn't this work?
