Hi, I have a question.When I read the NFC PN512 data manual, the PN512 chip USES UART to connect the MCU.In table 142, DTRQ pin is white, meaning input, but in fig14, DTRQ is output. Is this wrong or am I wrong?Thank you for answering.
I just got internal confirmation and you are right! It is an output. We already informed this to the corresponding internal team to be corrected.
Thank you!
Ivan.
