How to use Flash memory to save variable in the MC9S12P128
tanguydietrich
I want to save a variable in the D-Flash or P-Flash memory, to get it at the startup of the system.
I dont want to use a const variable. I want to be able to modifiy it and save it to use it after the shutdown of the systeme.
The board i am using is the KT33812ECUUG, the microcontroller i am using is the MC9S12P128.
Thank tou for your help.
tanguydietrich
I think I found the solution here.
confuse in memory map of mc9s12p128.
