HSADC on KV58F
Question asked by Christie Su on May 15, 2018
Latest reply on May 22, 2018 by Christie Su
I am using the sequence conversion sample to test HSADC on KV58F and works fine...
Then, I want to use the scan end interrupt in stead of polling. I can't make the interrupt to work.
When I use software to trigger the conversion and I can see the scanA end already generated, but no the interrupt routine is called...
Could you tell me why? How to make the interrupt to work?
Christie
