Debugger needed to enable Ethernet in MPC5748G LCEVB
rahulramakrishn
I am trying to exchange data between my pc and MPC5748G LCEVB through Ethernet port. I need to know which debugger need to be used to debug the code into MPC5748G LCEVB from S32DS. Currently I am using PE Micro's Multilink Universal debugger. While using this debugger, it shows a warning that PE Micro can't read register values. Then the debugger shows can't able to find the device.
So I want to know the debugger that need to be used to enable the Ethernet in MPC5738G LCEVB.
Rahul Ramakrishnan
