LPCOpen SD card drivers and Chan FatFs not compatible?
Question asked by James O on May 14, 2018
Latest reply on May 18, 2018 by Kerry Zhou
The 'periph_sdmmc' example (from LPCOpen v2.10 for the LPC1788 EA board) uses Chan FatFs with LPCOpen SD card drivers. However, the disk I/O function checker from the elm-chan FatFs webite (http://elm-chan.org/fsw/ff/res/app4.c) fails with the LPCOpen drivers.
Is there a fix to the LPCOpen library to make it fully work with Chan FatFs?
Alternatively, is there an example similar to 'periph_sdmmc' using FreeRTOS + FAT instead of the Chan FatFs?
Thank you.
