KEA8 CodeWarrior debug shell stdout redirect
changhehuang
Use CodeWarrior 10.6 debug shell to debug KEA8 by PnE U-MuliLink. Use "redirect stdout socket 6342" command to redirect the stdout to a Labview TCP/IP server port 6342. The connection was established successfully. Use "var counter" or "display counter" command, the "counter" data was displayed in the debugger shell, but no any data send to the Labview server.
Changhe Huang
