SPI Configuration for MKE04Z
murugaveluthang
Trying to configure MKE04Z series SPI for 16 Bit width configuration, but cannot find any registers to change the data width. Could someone guide on this, thank you. Have tried PE but it says the feature is not supported on this micro.
Muruga
mjbcswitzerland
Specialist V
The KE04 has 2 x 8 bit SPI interfaces and so you can't set it to 16 bits.
However if you send/receive 2 bytes an group then into 16 bits you will probably be able to still work on a 16 bit bus.
Mark
uTasker developer and supporter (+5'000 hours experience on +60 Kinetis derivatives in +80 product developments)
Kinetis: http://www.utasker.com/kinetis.html
