iMX7D, LPDDR2 minimum clock frequency
bardiabandali
The LPDDR2 memory timings in iMX7D datasheet are explained with CK=533MHz.
The question is what is the minimum supported clock frequency for LPDDR2 (e.g. does it support LPDDR2-400 like EDB8132B4BP-8D) ?
Thanks in advance,
Bardia
Labels (2)
joanxie
Given that there is no limit specified in the data sheet, it should operate that slowly, provided the clocking can be set for it to operate so slowly. As I knonwn, should be 24M, for EDB8132B4BP-8D, I suggest that you use ddr test to vertify this.
https://community.nxp.com/docs/DOC-105652
