PE_ISR(UnhandledInterrupt) { PE_DEBUGHALT(); }
isabelrevilla
Hi!
I have created a processor expert project for FRDM K64F board and while debugging if i try to send a value using the hyperterminal it stops working and the following error of Vectors.c appears:
PE_ISR(UnhandledInterrupt);
PE_DEBUGHALT();
I have tried to find the cause but i couldn't.
I attach the project.
Thanks very much
Hello Isabel Revilla ,
Please tell me which IDE and version you used , I will check your code on my side, thanks.
Alice
