Cannot communicate with the board, please try again. Exiting..
Question asked by zafer sen on May 8, 2018
Latest reply on May 27, 2018 by Dhvanil Patel
Hi.
KW41Z module on modular io gateway I want to update the software as described in Gateway => Radio Project => MKW41Z_Module_Firmware_Flashing_Guide.pdf documentation.
However, I am getting the error "Can not communicate with the board, please try again. For the solution of this error, they indicate a solution on the link below. However, after applying this solution, even though the problem is fixed, the same error occurs again when we update the serial software several times. And in each case I reinstall the bootloader software via the IAR IDE.
https://community.nxp.com/thread/441528
