How to configure PT0, PT1 for SCI(RXD1, TXD1) in S12ZVCA 48 pins?
aaronlee
Contributor V
I am using S12ZVCA 48 pins. How to configure PT0, PT1 for SCI(RXD1, TXD1) in Processor Expert?
P.S. I could only find SCI0(PS0, PS1) in MC9S12ZVCA192MLF.
Best Regard,
Aaron
Tags (3)
ZhangJennie
Hi Aaron,
I use CW11.
Your issue should be CW10.6 defect. and it has been fixed in latest CW11.
Jennie Zhang
ZhangJennie
hi.
Did you select the right channel in "Properties", please refer below to set yours.
Can this help you?
Jennie Zhang
aaronlee
Contributor V
I try to use configuration of 64 pins S12ZVCA. It can choice channel 1 now.
But my real MCU is 48 Pins. May i using 64 Pins configuration for 48 Pins MCU? or any recommand?
Aaron
ZhangJennie
Hi Aaron,
You need go to "Processors" to select right processor pin variant for your chip.
For detail, see attached video.
Jennie Zhang
aaronlee
Contributor V
Hi Jennie,
I following your video, but still no SCI1. (Please see attached video)
What version of Processor Expert are you using? How to upgrade?
ZhangJennie
Hi Aaron,
I use CW11.
Jennie Zhang
aaronlee
Contributor V
Hi Jennie,
Why does my SCI only channel 0? How to add channel 1?
Aaron
