use command 'apt-get install',then Could not open file /var/lib/dpkg/status
dragonred
I have been add 'bitbake apt' to fsl-image-gui , but I start the imx7 embedded system  and put command 'apt-get install'(with root identity)
it have shown 'Could not open file /var/lib/dpkg/status' , how could I solve the issue??(I need the fsl-image-gui image to use wifi network,alsa audio, gstreamer  , so not core-image-full-cmdline   ,aIthough I  know this tutorial)
Labels (3)
Tags (2)
