Ethernet imx6DL with KSZ9021 don't work with Gigabit connections
julianooliveira
I have a product based on IMX6DL board, and I'm using as O.S android jellybean. I have a strange behaviour related to ethernet Gigabit connections, after a connnection of this type, my board sundley turns off, and I don't receive any message of kernel panic or segmetation fault. Some advice of how to handle this kind of problem?
Labels (2)
Tags (2)
Hi Juliano
is it working reliably in uboot or linux . One can check i.MX6DL RGMII timings in
Table 60. RGMII Signal Switching Specifications  i.MX6SDL Datasheet  RGMII Pad Skew Registers
http://www.nxp.com/docs/en/data-sheet/IMX6SDLCEC.pdf
and if necessary try to adjust ksz9021 RGMII Pad Skew Registers.
