Sleep mode in MKW01Z
sergiiparadiuk
I use use sleep mode, but I can only wake in 65535 ms  seconds in maximum only.
I need to wake i time in 30 minutes. Is it possible to do?
My code for sleep mode:
PWRP_Init();
PWRP_ConfigureXCVRMode(pwrp_xcvr_sleep);
// Set timer source for wake up LPTM
PWRP_SetWakeUpSource(0x01);
PWRP_UpdateLPTMRCount(60 * 1000);
Enter_VLPS();
mjbcswitzerland
Specialist V
Hi Sergii
The LPTMR has a pre-scaler that can decrease its counting speed by /2, /4, /8 .../64k. If you enable that with an appropriate setting you can get much long delays up to 49.7 days from LPO clock.
Mark
uTasker developer and supporter (+5'000 hours experience on +60 Kinetis derivatives in +80 product developments)
Kinetis: http://www.utasker.com/kinetis.html
sergiiparadiuk
thank you for response, but I read this too, but how could I do from API?
2018-04-30 22:19 GMT+03:00 mjbcswitzerland <admin@community.nxp.com>:
NXP Community
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: Sleep mode in MKW01Z
reply from Mark Butcher
<https://community.nxp.com/people/mjbcswitzerland?et=watches.email.thread>
in Kinetis Microcontrollers - View the full discussion
<https://community.nxp.com/message/1010274?commentID=1010274&et=watches.email.thread#comment-1010274>
mjbcswitzerland
Specialist V
Sergii
I don't know the API that you are using - you will need to read its documentation or check its implemention. If it doesn't support the pre-scaler setting you can simply do the following (after you call the setup).
1. Disable the LPTMR with LPTMR0_CSR &= ~1;
2. Set the pre-scaler value you need (assuming LPO clock)
LPTMR0_PSR = (LPO_CLOCK_SOURCE | (DIVIDE_VALUE << 3));
3. Re-enable again LPTMR0_CSR |= 1;
where DIVIDE_VALUE is 1 for divide by 2, 2 for divide by 4, 3 for divide by 8, 4 for divide by 16 etc.
This will then increase the timeout value that you set by this factor.
Mark
sergiiparadiuk
thanks. It helped!
2018-05-01 0:19 GMT+03:00 mjbcswitzerland <admin@community.nxp.com>:
NXP Community
<https://community.nxp.com/message/1010279?commentID=1010279&et=watches.email.thread#comment-1010279>
