How to build CUPS on Yocto project
tsung-chihwang
Hi, I wanna build CUPS (Common Unix Printing System).
My steps as follows:
1. Download Yocto project
    $ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.14.38-6UL_ga
    $ repo sync
2. Image build
     MACHINE=imx6ulevk source fsl-setup-release.sh -b pisces -e fb
     $bitbake core-image-base
However, I cannot get CUPS finally.
I found cups_2.0.2.bb on this path sources/poky/meta/recipes-extended/cups.
My question is how to build cups_2.0.2.bb into rootfs.
Tags (2)
terry1
missing cups-filters and associated dependencies.
gusarambula
Hello Tsung-Chih Wang,
You can add the cups recipe to your image by adding the following line on the conf/local.conf file:
IMAGE_INSTALL_append = “ cups”
And then baking the image again.
I hope this helps!
tsung-chihwang
Hi Gusarambula,
Thanks for your great support.
I can build cups successfully~
Could you show me how to extract corresponding source code and make file of cups?
BR,
carter
gusarambula
Hello Carter,
The source code is fetched on demand. In case you have build the package already it would be available in one of the working directories, in this case something like:
<BSP_DIR>/<BUILD_DIR>/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/cups/<CUPS_VERSION>/cups-<VERSION>/cups/
Gustavo
