Hi All
Platform: i.MX8M-EVK
Software:Linux 4.9.51_GA
In the console execute as below command will show error message.
root@imx8mqevk:~# gst-launch-1.0 playbin uri=file://$FILE1 video-sink="overlaysink overlay-width=512 overlay-height=384"
Error message:
WARNING: erroneous pipeline: could not set property "video-sink" in element "playbin0" to "overlaysink overlay-width=512 overlay-height=384"
How to fix this error message?
Thanks.
Hi Hsu. I have encountered the same problem, but couldn't sovle it. What about you? Do you find any solutions?
hi
i am trying to run the example from the linux manual with the oversink on the imx8mm and get the same error. did you find a fix ?
Please run the command like "gst-inspect-1.0 | grep sink" to check all possibile ways to send the stream.
Victor
Hi Victor
overlaysink plugin is not found in the system.
( gst-inspect-1.0 | grep overlaysink is not displayed any plugins. )
How can I try multiple video overlays without using overlaysink?
Thanks.
I also have missing overlay sink error. How did you solve it.
