Dear NXP Community,
I have modified imx7dsabresd ref. design to use WIFI-BT AP6212
Would you advise on how to build the image?
Can I use any uart port for BT?
Hello
I highly recommend you to follow the below Yocto training. This training will guide you step by step how to build and customize your own Yocto image.
Diego.
thanks Diego,
I am fresh user to use iMX, do mfgtool is much simpliest to customize the build? should we create a new .vbs to add the new device?
MFG tool only works to load the Yocto image to your device in an easy way. To customize the build, you will need to modify or add new Yocto recipes. On the training that I posted before, it mentions how to modify a recipe.
Hope this can help you.
Diego.
thanks Diego again, I can't reach the url that you posted. it said Unauthorized
I apologize,
Can you please try with the below link:
https://community.nxp.com/docs/DOC-94849
Diego.
