MY-IMX6-MB200 hardware introduction
cherryzheng
overview of interfaces
front view
rear view
icon module
graphicinterface descriptionsilk screengraphicinterface descriptionsilk screen
118/24bit LVDS0J2420UART4_RS232P1
218/24bit RGBJ2321UART3_RS485J2
318/24bit LVDS1J2222MINI_PCIEJ6
410M/100M Ethernet-1P423UART2/3/4/5_TTLJ1
5EARJ2024GPIO/SD2J4
6MICJ1825SPI1/2J7
7HDMIJ1526SIM_CARDCON1
8PWR_SATAJ1227MIPI-CSIJ9
9MINIUSBJ1328CMOS_CSIJ14
10SATAJ1129CAN2J16
1110M/100M Ethernet-2P330CAN1J19
12USBHOSTJ831I2C1/2/3J21
13UART1_RS232P232GPS_ANTE4
14PWR_SwitchJ533GPSU15
15DC_5V_INJ334MINI_PCI_FPCJ26
16nRESETSW135SD3J25
17KEY1SW236WIFIU16
18KEY2SW337RTCU19
19KEY3SW438RTC_BatterBT1
interface function
18/24bit LVDS0
  silk screen:J24
  LVDS0 crystal liquid is 24 bit mode,compatible with 18bit mode,through which LVDS resistance screen panel and LVDS capacitor screen panel in different sizes and specifications produced by MYZR can be cnnected。LVDS0 interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation,better performance and connectivity 。
  definition of pin & signal as below:
pinsingnaldescription
J24-16SD1_DAT1/TOUCH_nEINT1GPIO control
J24-17NANDF_CS3GPIO control
J24-19DISP0_CONTRASTLVDS0 backlight adjustment
J24-21TOUCH_SCLII2C clock
J24-22TOUCH_SDAII2C data
18/24bit RGB
  silkscreen:J23
  RGB crystal liquid is 24bit mode,compatible to 18bit/16bit mode,through which RGB resistance screen panel and RGB capacitor screen panel in different sizes and specifications produced by MYZR can be cnnected,RGB interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation,better performance and connectivity。
  definition of pin & signal:
pin)signaldescription
J23-31SD1_DAT1/TOUCH_nEINT1GPIO control
J23-30NANDF_CS3GPIO control
J23-19DISP0_CONTRASTLVDS0 backlight adjustment
J23-32TOUCH_SCLI2C clock
J23-33TOUCH_SDAI2C data
18/24bit LVDS1
  silk screen:J22
  LVDS1 crystal liquid interface is the same as LVDS0 in terms of definition and connector model,users can connect crytal liquid in LVDS0 directly to LVDS1。
pinsignaldescription
J22-16SD1_DAT1/TOUCH_nEINT1GPIO control
J22-17NANDF_CS3GPIO control
J22-19DISP0_CONTRASTLVDS0 backlight adjustment
J22-21TOUCH_SCLI2C clock
J22-22TOUCH_SDAI2C data
10M/100M Ethernet-1
silk scree:P4
interface property:100 - Mbps Ethernet standard interface
earphone output
silk screen:J20
interface property:audio signal output,3.5mm interface
microphone input
silk screen:J18
interface propoerty:audio signal input,3.5mm interface
HDMI
silkscreen:J5
interface property:HDMI-1.4 standard interface
SATA power supply)
silkscreen:J12
J12-15VIN5V power input
J12-2GNDdigital
J12-3GNDdigital
J12-4NCunconnected
OTG
silkscreen:J5
interface property:USB ON-The-GO,for burn and write
SATA II
silkscreen:J11
interface property:3Gbps SATA II standard interface
10M/100M Ethernet-2
silkscreen:P3
USB expansion
silkscreen:J8
interface property:USB1 expanded to dual USB,standard USB interface
debug uart
silkscreen:P2
interface property:3 thread standard RS232 port,for debug of sirial port
main power supply switch
silkscreen:J3
interface property:power supply switch
status property:—,close;O,off
silkscreen:J4
interface property:
    jack with inside positive and outside negative
  voltage:5V
  current:2.5A及以上
reset
silkscreen:SW1
function:reset
wake up
silkscreen:SW2
interface property:sleeping wake up
volume up
silkscreen:SW3
interface property:volume control(volume up)
volume down
silkscreen:SW2
interface property:volume control(volume down)
RS-232 serial port
silkscreen:P1
interface property:UART4,3 thread standard RS232 port
RS-485 serial port
silkscreen:J2
interface property:UART3,RS-485 serial port
MINI-PCIE
silkscreen:J6
interface property:standard MINI-PCIE port
serial port expansion/TTL electrical level
silkscreen:J1
GPIO/SD2
silkscreen:J4
SPI expansion
silkscreen:J7
SIM cassette
silkscreen:CON1
interface property:standard SIM cassette
MIPI-CSI
silkscreen:J9
CMOS-CSI
silkscreen:J14
CAN2
silkscreen:J16
interface property:CAN2
CAN1
silkscreen:J19
interface property:CAN1
I2C expansion
silkscreen:J21
GPS antenna pedestal
silkscreen:E4
interface property:antenna pedestal
GPS
silkscreen:U15
module model:NEO-6M
MINI_PCIE_FPC
silkscreen:J26
note:can't be used with MINI_PCIE simultaneously,e.g can only choose one from the two。
SD3
silkscreen:J25
interface property:standard SD cassette
WIFI
silkscreen:U16
module model:UM12BS
RTC
silkscreen:U19
interface property:real clock for I2C communication
RTC_Batter
silkscreen):BT1
If you would like to know more about our products, please visit our website www.myzr-tech.com or email to enquiry@myzr.com.cn.
Labels (3)
