K66 connecting SDRAM with 32bit data path
Question asked by unknowncoder on Apr 25, 2018
Latest reply on Apr 27, 2018 by Daniel Chen
I want to connect a SDRAM with a 32bit data path to the K66?
The user guide specifies that the K66 supports 32bit data path. But I noticed that the SDRAM data pins only support 16 bit data path.
Is it possible to use the Flexbus to compensate for the additional 16 data pins that are missing? If so how do I do this?
There is nothing in the user guide that specifies how to use a 32bit data path. Is it possible the user guide has mistakes?
