Android Oreo lunch sabresd_6dq_car-userdebug not working on sabresd 6dl board
vivektol
            We have NXP Sabresd  MCIMX6DL-SDP evaluation board.
We have downloaded Oreo build and compiling with  lunch sabresd_6dq_car-eng  or sabresd_6dq_car-userdebug  option.
But the images created are not working on sabresd board.
Attaching the message we are getting while booting the board.
Please let us know what is the reason why car build is not working on our board.
With Regards,
VIVEK TOL
diegoadrian
Are you trying to enter Android recovery mode?
Diego.
vivektol
Hello Diego,
I have follow below steps with oreo source code,
$ source build/envsetup.sh
$ lunch sabresd_6dq_car-userdebug
$ make 2>&1 | tee build-log.txt
copy images in android_O8.0.0_1.0.0_mfg_tools   and  burn images in NXP Sabresd  MCIMX6DL-SDP evaluation board emmc.
When I boot the board I am getting attach message on HDMI. If I press anything recover recovery, factory reset then also I am getting same screen again.
Please guide how to run this sabresd_6dq_car-userdebug on sabresd MCIMX6DL-SDP evaluation board.
With Regards,
VIVEK TOL
diegoadrian
I apologize for the delay,
Unfortunately, our hardware does not support this building name, you will need to use the ones that are specified in the Android User's Guide, I apologize for the inconveniences.
Diego
