Cherry Zheng
NXP i.mx6ull SOM(MY-i.MX6-CB140)
Discussion created by Cherry Zheng on Apr 25, 2018
MY-i.MX6-CB140 core board
  •      CPU:MX6UL/i.MX6ULL, 528 MHz/800 MHz
  •       Memory:256MB DDR3,up to 512MB
  •      Storage:256MB EMMC,up to 4GB
  •      Power Supply:5V+10%
  •      Size:36mmX38mm
  •      Temperature:
0°C..75°C (Commercial)
  -40°C..85°C(Industrial)
-40°C..105°C(Automotive)
Main Features:
  •       Single ARM Cortex-A7 MPCore, 528MHz operating frequency, 128KB L2 cache
  •      Power Management Units with DC-DC switched converter supporting Li-lon batteries, Dual-Megabit Ethernet Controller (IEEE1588 compliant), 10/100 Mbps
  •      Two FlexCAN2 interfaces
  •      Two High Speed (HS) USB 2.0 OTG, with integrated HS USB Phy
  •      2x12-bit ADC with 10 channel, 4-wire resistive touch screen controller
  •      Thermal protection temperature sensor
  •      Multiple connection interfaces(8xUARTs、SSP、SDIO、SPI、I2C、I2S)
  •      Low-cost 454MHz ARM9
  •      Industrial temperature range
  •      Highly integrated stamp hole pin
  •      Size up to 36mmX38mm
OS Support:
  •      Linux 3.14.52/Linux-4.1.15, QT4
hardware configuration
CPU
i.MX 6UltraLite/ i.mx6ull
compatible to automotive, industrial, commercial
Memory
DDR3 256MB
Up to 512MB
Storage
256MB eMMC
Up to 4GB
Operating system support
Operating system & version
MY-IMX6-EK200
MY-IMX6-EK314
MY-IMX6-EK336
MY-IMX6-EK140
Linux
Linux-3.0.35
YES
YES
Linux-3.14.52
YES
YES
YES
YES
Android
Android 4.2.2
YES
Android 4.4.2
YES
YES
QT
QT-4.8.5
YES
YES
YES
QT-5.5.0
YES
YES
YES
Ubuntu
Ubuntu 11.10
YES
YES
Ubuntu 12.04
YES
YES
Defaulted interface of hardware
defaulted interface
?CCM
CCM_CLK1
support
external clock output
PMIC_STBY_REQ
support
used for core board
ECSPI
ECSPI1
support
1 chip select
ECSPI2
support
1 chip select
ENET
ENET1
support
10/100-Mbps
FLEXCAN
FLEXCAN1
support
FLEXCAN2
support
GPIO
GPIO1
support
two used for SDI,two used for ENET1
GPIO4
support
1 used for RTC
GPIO5
support
nine used for universal GPIO, one used for touch
I2C
I2C1
support
I2C2
support
eLCDIF
LCDIF
support
24 bit
PWM
PWM2
support
PWM4
support
used for LCD backlight control
PWM5
support
JTAG
SJC
support
SRC
ONOFF
support
POR_B
support
external re-set signal
BOOT_MODE0
support
Boot mode control
BOOT_MODE1
support
Boot mode control
UART
UART1
support
can support RS485
UART2
support
UART3
support
UART4
support
UART5
support
UART6
support
UART7
support
UART8
support
can support RS485
USB
USB_OTG1
support
used for USB OTG interface
USB_OTG2
support
used for USB HOST interface
uSDHC
uSDHC1
support
4 bit
uSHDC2
support
8bit,used for eMMC of core board
WDOG
WDOG1
support
Definition of pin
Order no.
Pin name
 Signal name
Interface
Function
Mode
Direction
001
CCM_CLK1_N
CLK1_N
CCM
ccm_clk1_n
002
CCM_CLK1_P
CLK1_P
CCM
ccm_clk1_p
003
GPIO1_IO08
WDOG_B
WDOG1
wdog_wdog_b
ALT1
Input/Output
004
GPIO1_IO05
PWM_4
PWM4
pwm_out
ALT1
Output
005
GPIO1_IO09
PWM_2
PWM2
pwm_out
ALT0
Output
006
NAND_DQS
PWM_5
PWM5
pwm_out
ALT3
Output
007
GPIO1_IO02
USB_OTG2_PWR
(ENET_nRST)
GPIO1
gpio_io2
ALT5
Input/Output
008
GPIO1_IO01
USB_OTG1_OC
(SD1_CD)
GPIO1
gpio_io1
ALT5
Input/Output
009
GPIO1_IO04
USB_OTG1_PWR
(SD1_WP)
GPIO1
gpio_io4
ALT5
Input/Output
010
GPIO1_IO03
USB_OTG2_OC
(ENET_nINT)
GPIO1
gpio_io3
ALT5
Input/Output
011
UART2_RTS_B
CAN2_RX
FLEXCAN2
can_rx
ALT2
Input
012
UART2_CTS_B
CAN2_TX
FLEXCAN2
can_tx
ALT2
Output
013
UART3_RTS_B
CAN1_RX
FLEXCAN1
can_rx
ALT2
Input
014
UART3_CTS_B
CAN1_TX
FLEXCAN1
can_tx
ALT2
Output
015
GPIO1_IO07
ENET_MDC
ENET1
enet_mdc
ALT0
Output
016
GPIO1_IO06
ENET_MDIO
ENET1
enet_mdio
ALT0
Input/Output
017
ENET1_TX_DATA1
ENET1_TXD1
ENET1
enet_tdata1
ALT0
Output
018
ENET1_TX_EN
ENET1_TXEN
ENET1
enet_tx_en
ALT0
Output
019
ENET1_RX_DATA0
ENET1_RXD0
ENET1
enet_rdata0
ALT0
Input
020
ENET1_TX_DATA0
ENET1_TXD0
ENET1
enet_tdata0
ALT0
Output
021
ENET1_RX_DATA1
ENET1_RXD1
ENET1
enet_rdata1
ALT0
Input
022
ENET1_TX_CLK
ENET1_TX_CLK
ENET1
enet_tx_clk
ALT0
Input
023
ENET1_RX_EN
ENET1_CRS_DV
ENET1
enet_rx_en
ALT0
Input
024
ENET1_RX_ER
ENET1_RXER
ENET1
enet_rx_er
ALT0
Input
025
UART1_RX_DATA
UART1_RXD
UART1
uart_rx
ALT0
Input
026
UART1_CTS_B
UART1_CTS
UART1
uart_cts_b
ALT0
Output
027
UART1_TX_DATA
UART1_TXD
UART1
uart_tx
ALT0
Output
028
UART1_RTS_B
UART1_RTS
UART1
uart_rts_b
ALT0
Input
029
UART2_TX_DATA
UART2_TXD
UART2
uart_tx
ALT0
Output
030
UART2_RX_DATA
UART2_RXD
UART2
uart_rx
ALT0
Input
031
UART3_TX_DATA
UART3_TXD
UART3
uart_tx
ALT0
Output
032
UART3_RX_DATA
UART3_RXD
UART3
uart_rx
ALT0
Input
033
UART4_TX_DATA
UART4_TXD
UART4
uart_tx
ALT0
Output
034
UART4_RX_DATA
UART4_RXD
UART4
uart_rx
ALT0
Input
035
UART5_TX_DATA
UART5_TXD
UART5
uart_tx
ALT0
Output
036
UART5_RX_DATA
UART5_RXD
UART5
uart_tx
ALT0
Output
037
ENET2_RX_ER
UART8_CTS
UART8
uart_cts_b
ALT1
Output
038
ENET2_RX_DATA1
UART6_TXD
UART6
uart_tx
ALT1
Output
039
ENET2_TX_CLK
UART8_RTS
UART8
uart_rts_b
ALT1
Input
040
ENET2_RX_DATA0
UART6_RXD
UART6
uart_rx
ALT1
Input
041
ENET2_TX_EN
UART8_TXD
UART8
uart_tx
ALT1
Output
042
ENET2_RX_EN
UART7_TXD
UART7
uart_tx
ALT1
Output
043
ENET2_TX_DATA1
UART8_RXD
UART8
uart_rx
ALT1
Input
044
ENET2_TX_DATA0
UART7_RXD
UART7
uart_rx
ALT1
Input
045
GND
046
5V
047
5V
048
5V
049
DCDC_3V3
050
VDD_SNVS_IN
Output
051
GND
052
GND
053
LCD_DATA23
LCD_DATA23
LCDIF
lcdif_data23
ALT0
Input/Output
054
LCD_DATA19
LCD_DATA19
LCDIF
lcdif_data19
ALT0
Input/Output
055
LCD_DATA20
LCD_DATA20
LCDIF
lcdif_data20
ALT0
Input/Output
056
LCD_DATA21
LCD_DATA21
LCDIF
lcdif_data21
ALT0
Input/Output
057
LCD_DATA22
LCD_DATA22
LCDIF
lcdif_data22
ALT0
Input/Output
058
LCD_DATA17
LCD_DATA17
LCDIF
lcdif_data17
ALT0
Input/Output
059
LCD_DATA18
LCD_DATA18
LCDIF
lcdif_data18
ALT0
Input/Output
060
LCD_DATA13
LCD_DATA13
LCDIF
lcdif_data13
ALT0
Input/Output
061
LCD_DATA14
LCD_DATA14
LCDIF
lcdif_data14
ALT0
Input/Output
062
LCD_DATA08
LCD_DATA8
LCDIF
lcdif_data8
ALT0
Input/Output
063
LCD_DATA09
LCD_DATA9
LCDIF
lcdif_data9
ALT0
Input/Output
064
LCD_DATA07
LCD_DATA7
LCDIF
lcdif_data7
ALT0
Input/Output
065
LCD_DATA06
LCD_DATA6
LCDIF
lcdif_data6
ALT0
Input/Output
066
LCD_DATA05
LCD_DATA5
LCDIF
lcdif_data5
ALT0
Input/Output
067
LCD_DATA04
LCD_DATA4
LCDIF
lcdif_data4
ALT0
Input/Output
068
LCD_DATA00
LCD_DATA0
LCDIF
lcdif_data0
ALT0
Input/Output
069
LCD_DATA01
LCD_DATA1
LCDIF
lcdif_data1
ALT0
Input/Output
070
LCD_DATA10
LCD_DATA10
LCDIF
lcdif_data10
ALT0
Input/Output
071
LCD_DATA15
LCD_DATA15
LCDIF
lcdif_data15
ALT0
Input/Output
072
LCD_DATA16
LCD_DATA16
LCDIF
lcdif_data16
ALT0
Input/Output
073
LCD_DATA12
LCD_DATA12
LCDIF
lcdif_data12
ALT0
Input/Output
074
LCD_DATA11
LCD_DATA11
LCDIF
lcdif_data11
ALT0
Input/Output
075
LCD_DATA03
LCD_DATA3
LCDIF
lcdif_data3
ALT0
Input/Output
076
LCD_DATA02
LCD_DATA2
LCDIF
lcdif_data2
ALT0
Input/Output
077
LCD_RESET
LCD_RESET
LCDIF
lcdif_reset
ALT0
Input/Output
078
LCD_VSYNC
LCD_VSYNC
LCDIF
lcdif_vsync
ALT0
Input
079
LCD_HSYNC
LCD_HSYNC
LCDIF
lcdif_hsync
ALT0
Input
080
LCD_CLK
LCD_PCLK
LCDIF
lcdif_clk
ALT0
Input
081
LCD_ENABLE
LCD_DE
LCDIF
lcdif_enable
ALT0
Input/Output
082
GND
083
CSI_PIXCLK
I2C1_SCL
I2C1
i2c_scl
ALT3
Input/Output
084
CSI_MCLK
I2C1_SDA
I2C1
i2c_sda
ALT3
Input/Output
085
NAND_CE1_B
NAND_CE1N
(RTC_nRQ)
GPIO4
gpio_io14
ALT5
Input/Output
086
SD1_CLK
SD1_CLK
uSDHC1
usdhc_clk
ALT0
Output
087
SD1_DATA3
SD1_DATA3
uSDHC1
usdhc_data3
ALT0
Input/Output
088
SD1_DATA0
SD1_DATA0
uSDHC1
usdhc_data0
ALT0
Input/Output
089
SD1_DATA1
SD1_DATA1
uSDHC1
usdhc_data1
ALT0
Input/Output
090
SD1_DATA2
SD1_DATA2
uSDHC1
usdhc_data2
ALT0
Input/Output
091
SD1_CMD
SD1_CMD
uSDHC1
usdhc_cmd
ALT0
Input/Output
092
GND
093
CSI_DATA06
ECSPI1_MOSI
ECSPI1
ecspi_mosi
ALT3
Input/Output
094
CSI_DATA02
ECSPI2_MOSI
ECSPI2
ecspi_mosi
ALT3
Input/Output
095
CSI_DATA07
ECSPI1_MISO
ECSPI1
ecspi_miso
ALT3
Input/Output
096
CSI_DATA04
ECSPI1_SCLK
ECSPI1
ecspi_sclk
ALT3
Input/Output
097
CSI_DATA00
ECSPI2_SCLK
ECSPI2
ecspi_sclk
ALT3
Input/Output
098
CSI_DATA05
ECSPI1_CS0
ECSPI1
ecspi_ss0
ALT3
Output
099
CSI_DATA01
ECSPI2_CS0
ECSPI2
ecspi_ss0
ALT3
Output
100
CSI_DATA03
ECSPI2_MISO
ECSPI2
ecspi_miso
ALT3
Input/Output
101
GND
102
CSI_HSYNC
I2C2_SCL
I2C2
i2c_scl
ALT3
Input/Output
103
CSI_VSYNC
I2C2_SDA
I2C2
i2c_sda
ALT3
Input/Output
104
GND
105
GND
106
GND
107
SNVS_TAMPER5
SNVS_TAMPER5
(TOUCH_nEINT0)
GPIO5
gpio_io5
ALT5
Input/Output
108
SNVS_TAMPER8
SNVS_TAMPER8
GPIO5
gpio_io8
ALT5
Input/Output
109
SNVS_TAMPER1
SNVS_TAMPER1
GPIO5
gpio_io1
ALT5
Input/Output
110
SNVS_TAMPER4
SNVS_TAMPER4
GPIO5
gpio_io4
ALT5
Input/Output
111
SNVS_TAMPER3
SNVS_TAMPER3
GPIO5
gpio_io3
ALT5
Input/Output
112
SNVS_TAMPER7
SNVS_TAMPER7
GPIO5
gpio_io7
ALT5
Input/Output
113
SNVS_TAMPER0
SNVS_TAMPER0
GPIO5
gpio_io0
ALT5
Input/Output
114
SNVS_TAMPER2
SNVS_TAMPER2
GPIO5
gpio_io2
ALT5
Input/Output
115
SNVS_TAMPER6
SNVS_TAMPER6
GPIO5
gpio_io6
ALT5
Input/Output
116
SNVS_TAMPER9
SNVS_TAMPER9
GPIO5
gpio_io9
ALT5
Input/Output
117
GND
118
SNVS_PMIC_ON_REQ
PMIC_ON_REQ
SNVS
snvs_lp_wrapper
_pmic_on_req
ALT0
Input
119
ONOFF
ONOFF
SRC
src_reset_b
ALT0
Input
120
POR_B
POR_B
SRC
src_por_b
ALT0
Input
121
BOOT_MODE1
BOOT_MODE1
SRC
src_boot_mode1
ALT0
Input
122
BOOT_MODE0
BOOT_MODE0
SRC
src_boot_mode0
ALT0
Input
123
GND
124
USB_OTG2_VBUS
USB_OTG2_VBUS
USB
usb_otg2_vbus
125
USB_OTG2_DP
USB_OTG2_DP
USB
usb_otg2_dp
126
USB_OTG2_DN
USB_OTG2_DN
USB
usb_otg2_dn
127
GND
128
USB_OTG1_VBUS
USB_OTG1_VBUS
USB
usb_otg1_vbus
129
USB_OTG1_DP
USB_OTG1_DP
USB
usb_otg1_dp
130
USB_OTG1_DN
USB_OTG1_DN
USB
usb_otg1_dn
131
GND
132
USB_OTG1_CHD_B
nUSB_OTG_CHD
USB
usb_otg1_chd_b
133
GPIO1_IO00
USB_OTG1_ID
USB
usb_otg1_id
ALT2
Input
134
JTAG_TRST_B
JTAG_nTRST
SJC
sjc_trstb
ALT0
Input
135
JTAG_TMS
JTAG_TMS
SJC
sjc_tms
ALT0
Input
136
JTAG_MOD
JTAG_MOD
SJC
sjc_mod
ALT0
Input
137
JTAG_TCK
JTAG_TCK
SJC
sjc_tck
ALT0
Input
138
JTAG_TDO
JTAG_TDO
SJC
sjc_tdo
ALT0
Output
139
JTAG_TDI
JTAG_TDI
SJC
sjc_tdi
ALT0
Input
140
GND
If you would like to know more about our products, please visit www.myzr-tech.com or email to enquiry@myzr.com.cn.
