How to check which interrupt has fired now?
Question asked by vikranth Nk on Apr 25, 2018
Latest reply on Apr 25, 2018 by Mark Butcher
I am using both receive and transmit interrupts, but in my code interrupt handler is only one for both receive and transmit is it right?
Iam using FRDMKE04 dev board,    and    SDK_2.3.1_FRDM-KE04Z
following is my sample code
#include "board.h"
#include "fsl_uart.h"
#include "pin_mux.h"
void UART0_IRQHandler(void)
   if(receive interrupt)  ///// I need to know this condition
      uint8_t data;
      /* If new data arrived. */
      if ((kUART_RxDataRegFullFlag | kUART_RxOverrunFlag) & UART_GetStatusFlags(UART0))
            data = UART_ReadByte(UART0);
            // Copy the byte into the local FIFO, if it won't cause an overflow
            if(UART_RxBuffer_WritePtr < EUSART_RX_BUFFER_SIZE)
                  UART_RxBuffer[UART_RxBuffer_WritePtr++] = data;
                  if(UART_RxBuffer_WritePtr >= EUSART_RX_BUFFER_SIZE)
                     UART_RxBuffer_WritePtr = 0;
                  UART_NumBytesInRxBuffer++; /* Update counter */
   elseif(transimit interrupt is fired) ///// I need to know this condition
