Invisible entries in debugger call stack
Question asked by SCOTT MILLER on Apr 22, 2018
Latest reply on Apr 23, 2018 by SCOTT MILLER
This seems to happen to me frequently - I'll pause the debugger and the call stack will show up with a bunch of invisible entries.  You can see that I've expanded the invisible list and highlighted one.  If I use the 'copy stack' context menu item, it copies everything to the clipboard, so I know it's there.  Is this a known bug?  Is there a fix?
Also, no idea if it's related, but Peripherals+ only works sporadically.  You can see that nothing is showing up in the Peripherals+ pane.
I'm running MCUX 10.1.1_606, and my debug interface is a P&E Cyclone ACP.
Scott
