Change mcuxpresso config tool's language
chancehuang
Hello!
I'm new to mcuxpresso config tool.
May I know how to change the LANGUAGE from "Chinese" to "ENGLISH"?
I did select "ENGLISH" during installing.
Thanks for your help!
marek-trmac
Hi Chance Huang, from the documentation:
1.2 Tools localization
The Tools support English and Chinese languages, based on your locale settings.
To manually set the locale, add the following parameter to the command line:
tools.exe -nl zh
It is possible to set the locale in the tools.ini file by adding the following line:
-Duser.language=zh
The supported languages are:
• en - English
• zh – Chinese
Marek
Marek
chancehuang
Dear Marek,
   Thanks a lot for your help!
   I did it, and worked.
   By the way, we choose "MK40DX256VLL7", which is 100-pin PQFP, for our design.
   However, I only found "MK40DX256VLQ10 - LQFP 144 package" from MCUexpresso.
   Is the MCUexpresso right tool for me? or what am I wrong?
   Appreciate your help!!
marek-trmac
Hi again,
I found in this document: https://community.nxp.com/docs/DOC-333073 that MK40DX256VLL7 is not planned in MCUXpresso IDE and MCUXpresso Config Tools.
Marek
Marek
chancehuang
Dear Marek,
Got it!
If I'd like to configure the pin of  "MK40DX256VLL7/ 100-pin PQFP", any suggestion tool?
Thanks!!
ZhangJennie
Hi Chance,
You can use KDS with processor expert. it supports MK40DX256VLL7
Jennie Zhang
chancehuang
Dear Jennie,
   Thanks for your information!!
Chance
ZhangJennie
welcome!
Jennie Zhang
