I compared two errata(IMX6SLLCE.pdf and IMX6SLCE.pdf) then found known EDDC errata ERR005313 disappeared.
I guess errata was fixed but I couldn't find any descriptions in "i.MX 6SLL Migration Guide: AN11988.pdf".
Has the errata ERR005313 been already fixed?
If someone know it, please let me know.
ERR005313 EPDC: Incorrect data fetched when the buffer update width is 2048 pixels or greater
Description:
When sending an image update to a high resolution panel with an image buffer width ≥ 2048 pixels,
the EPDC module fetches incorrect data because an internal address register is incorrectly
truncated.
Solved! Go to Solution.
Hello Torus1000,
I confirmed that this erratum was fixed since i.MX6SL and it is also fixed on the i.MX6SLL.
I hope this helps!
Hello Torus1000,
I hope this helps!
