Hello All,
I am using a code warrior 5.9.0 version and i am using an MPC5554 microcontroller board . Now my problem is I am trying to load the ELF file generated in the code warrior but it is not loading . It is creating problem like there will be some program counter it is getting reset to some value. So is there any procedure i should follow to load the ELF file into internal flash . Please do help me out with this. By the way thanks in advance.
Manikandan Kannan
