After I got the MPC5604EKIT, the following is my operation:
1. Read the “MPC5604EKIT-Quick-Start-Guide.pdf”, and execute as Quick-Start-Guide.
2. Download VLC player 1.1.11 ( Windows ).
3. Change my PC computer IP address to 192.168.1.1/255.255.255.0.
4. Use BoardR-Reach cable to connect 12V power supply to the Mini:J1:.
5. Execute CMD: vlc.exe --demux=mjpeg.
5. Enter udp://@: 1234 for the network URL for VLC player.
6. Connect the Ethernet cable coming from the Host PC to the Mini:J2:ETH_CONN.
7. Reset key.
Then I found that without data on PC VLC player. Only I can see was the DS1(Green LED) light up, the DS6(Orange LED) light up, and on the begining, the DS5(Green LED) flicker, but finish extinguish.
As the Quick-Start-Guide said, I should watch the vedio data of camera.
What's wrong ?
How could I run it?
Did I need to load programe for KIT? I have download the "FSL_SALSAREFKIT_MPC5604E_APTINA_EAR_0.8.2", that's what only I can find on net.
Please give me some help.
