Can I use MXP2202AP sensor (or similar) to sense water pressure?
avelasco
I found in the datasheet that:The MPX2200 series pressure sensor operating characteristics and internal reliability and qualification tests are based on use of dry air as the pressure media. Media other than dry air may have adverse effects on sensor performance and long term reliability. Contact the factory for information regarding media compatibility in your application.
I need to know if it is possible to sense watwer pressure..?
please help!
TomasVaverka
Hi Andrea,
Thank you for your interest in NXP pressure sensors!
Please have a look at this thread with a long discussion on this topic.
I hope it helps.
Tomas
