Off-Chip Trace i.MX6UL
Question asked by guillaume17 on Apr 11, 2018
I'm looking for information or documents that tell me how to use the trace feature on i.MX6UL.
I saw that there was an Embedded Trace Macrocell (ETM) and Embedded Trace Buffer (ETB). In this case, it is necessary to read with the JTAG the buffer (ETB).
I would like in my case to make code coverage. I think the best solution is to use the trace port unit. However, I can not find the port to use and the pins.
Is it possible to recover the traces with for example the LAUTERBACH Off-Chip Trace Solution probe ?
Is the trace port available and if so where can I find the pins?
Thanks for your help
Cordially
