FAN control support on i.MX8M
ansonlin
Can i.MX8M support fan control that has PWM output and tachometer input?
I want to know how to  connect these two pin to i.MX8M
vinoth_ta
Hi Anson Lin,
Did you get the response? I am having same query.
Vinoth TA
ansonlin
Hi Rita,
Please find below link and description.
The tachometer signal, also known as "tach signal", and "FG signal", conveys rpm information in the form of square waves. The frequency of this square wave output is proportional to the rotation of the shaft.
CPU Cooling Fan Tachometer Standard
ansonlin
Hi Rita,
The FAN control that I need is " PWM output and tachometer input". Please help to check if i.MX8M can support " PWM output and tachometer input"
Rita_Wang
Hi Anson,
About the "PWM output" is supported by the i.MX8M, and the tachometer could you tell us what is the interface of the  "tachometer". If the interface is I2C or SPI, the i.M8M is supported the tachometer input.
Have a nice day
Rita
Rita_Wang
Hi Anson,
You can refer to the i.MX8M-EVK board hardware design https://www.nxp.com/webapp/sps/download/preDownload.jsp .
Hope this can do help for you.
Have a nice day
Rita
ansonlin
Hi Rita,
I didn't find the useful FAN control circuit on i.MX8M EVK schematic(SPF-29615_B3). I just find a J802 for FAN PWR. Please kindly check it
Rita_Wang
In our hardware design there is no control for the DCDC_5V, we only supply the 5V power. So if you need to control it, yo can drive the power by the turn-on and turn-off via the temperature control.
