PCT 2075, Behaviour of reading above +125 degrees
Question asked by Kattinti Siva Krishna on Apr 9, 2018
Latest reply on Apr 11, 2018 by Kattinti Siva Krishna
Hi All,
I am working on PCT2075 temperature sensor.
I have a doubt, From data sheet of PCT2075, Section 7.4.3 indicates, temperature reading of raw data. I am not having problem while reading temperature data up to 125 degrees. But still if I am increasing the temperature on temperature sensor what happen (Eg:130 Degrees),  Whether it will show as negative value or the particular register will return as 125 degree value as its temperature sensor is already reached its maximum temperature value.
Did any one tried it.
It will be great if you provide inputs on this.
Siva.
