Building KBOOT Under KDS
jeremyanderson
I'm trying to just get a compile, but when I import the projects I think I need I run into problems with my KDS configuration right away.  Here is the message (any ideas?):
Orphaned configuration. No base extension cfg exists for ilg.gnuarmeclipse.managedbuild.cross.config.elf.debug.1792027861
mjbcswitzerland
Specialist V
Jeremy
Which source are you using?
It sound like either a KDS problem or you are opening an Eclipse project that is not compatible with KDS.
Mark
uTasker developer and supporter (+5'000 hours experience on +60 Kinetis derivatives in +80 product developments)
Kinetis: http://www.utasker.com/kinetis.html
jeremyanderson
I imported the projects from NXP Kinetis Bootloader 2.0.0 targets\MK66F18\kds
jorge_a_vazquez
Hi Jeremy Anderson
I'm using Kinetis Desing Studio 3.2 and the latest MCUBoot Software, I have not a problem to compile the code under Bootloader 2.0.0 targets\MK66F18\kds\frdm-k66f
Do you have the latest KDS version? also, could you try to check for updates under help tab?
Jorge Alcala
