For an image processing application I want to use imx6 quad plus module.
The RAW image will be supplied by an FPGA.
I see that CSI-2 interface can be used to supply video. However this requires license costs for the FPGA IP.
Are there other ways I can feed the RAW images from the FPGA avoiding the costs of specialized IPs? Is camera parallel interface simpler to implement? Are three other ways?
thanks in advance
Hi Milke,
For parallel camera example one can look at imx6qdl-sabresd.dtsi
