PCIe SATA android 7.1.2 support for iMX6q
Question asked by HARISH KUMAR T S on Apr 4, 2018
Latest reply on Apr 6, 2018 by igorpadykov
Working with Android 7.1.2 imx6q board with PCIe external SATA module, The Android kernel level able to see the sda1 SATA driver partition and able to read/write the storage in kernel level, But the Android UI not getting the SATA storage drive.
Below given device mounted list,And that /dev/block/sda removable device is not mounted here
tmpfs 1029200 4 1029196 1% /mnt
/dev/block/mmcblk0p3           1499760    708564    791196    48%    /system
/dev/block/mmcblk0p10         1430704    23240      1407464    2%    /data
/dev/block/mmcblk0p4            499656      416          499240      1%    /cache
/dev/block/mmcblk0p5             6907          45            6862          1%   /device
/dev/fuse                                  1430704    23240      1407464    2%   /mnt/runtime/default/emulated
/dev/fuse                                  1430704    23240      1407464    2%   /mnt/runtime/read/emulated
/dev/fuse                                  1430704    23240      1407464    2%   /mnt/runtime/write/emulated
/dev/block/vold/public:179:33   7821312   3384552   4436760  44%   /mnt/media_rw/9CB0-C8A5
/dev/fuse                                   7821312   3384552   4436760  44%   /mnt/runtime/default/9CB0-C8A5
/dev/fuse                                   7821312   3384552   4436760  44%   /mnt/runtime/read/9CB0-C8A5
/dev/fuse                                   7821312   3384552    4436760 44%   /mnt/runtime/write/9CB0-C8A5
So please help to view the SATA storage drive in Android UI.
Harish Kumar
