MPC5748 CAN FD with a PCAN-USB Pro FD
khaledbrahem
I'm having some problems when connecting CAN FD with a PCAN-USB Pro FD
tests done :
FlexCANx sending to FlexCANy :OK
PCAN listening on  FlexCANx sending  to FlexCANy :OK
PCAN sending to  FlexCANx : not OK
error discription
MPC5748 side : RXWRN error occuring but some frames are received
PCAN side : error passive then bus-off
config MPC5748 :
16 Mhz CLK
CAN nominal bitrate 250 Kbis/s
CAN data bitrate 2000 Kbits/s
FPRESDIV = 0
FRJW = 0
FPROPSEG = 3
FPSEG1 = 1
FPSEG2 = 1
config PCAN: check joined photos
Tags (4)
