Mag3110 improper output
Question asked by Deepanraj Anbarasan on Apr 2, 2018
Latest reply on Apr 5, 2018 by Deepanraj Anbarasan
We are currently using imx6 based custom board which contains mag3110 magnetometer sensor.
To test the sensor we are running the evtest.
When running the evtest application for mag3110.Both the x and y axis value seemed to get either negative no matter what ever position we place the sensor.Is there any setting required to correct this. Since we tested in another board containing the mag3110 sensor, the value from the sensor seemed to change from positive to negative for x and y axis depending upon the position.
Please help us solve this issue since we are not sure what could be the reason for this behavior.
Thank you,
Deepanraj.A
