Neo Xiong
Can MCUXpresso IDE provide a better map viewer?
Discussion created by Neo Xiong Employee on Apr 1, 2018
Latest reply on Apr 8, 2018 by Neo Xiong
Hi, MCUXpresso Expert
When I'm using MCUXpresso (LPCXpresso, or KDS) and trying to analyze & optimize memory footprint, I feel it is very inconvenient to use the .map file generated by gcc. Both IAR and KEIL linker gives a summary by files and libs, I can clearly know which files used most of the memory, so I can further look into the code.
Is it possible for MCUXpresso IDE to provide a tool to summarize such a table from .map? Or equivalent (or better, e.g. graphic) way is also welcome. Thanks.
IAR
  KEIL
