Subject: Non-chip-select burst in 16-bit data bus mode
Is it possible to configure the special case of a non-chip-select 32-bit access in 16-bit data bus mode (DBM = 1 in EBI_MCR) with the Address[16:31] / Data multiplexing ?
Chapter 22.4.2.9 of MPC5675K reference manual
Thanks in advance
Hi, definitely not with 257 MAPBGA package that does not have external bus. For EBI you must use 473 MAPBGA package.
With bigger package mentioned non-cs access is possible to use.
