silk screen:SW1
mode control | 1bit | 2bit |
burning model | 1 | 0 |
booting mode | 0 | 1 |
silk screen:SW2
interface property: volume control(volume down)
silk screen:SW3
interface property: volume control(volume up)
silk screen:SW4
interface property:sleeping wake up)
silk screen:SW5
interface property: system reset
silk screen:J20
LVDS0 crystal liquid is 24bit mode,compatible to 18bit mode,through which LVDS resistance screen panel and LVDS capacitor screen panel in different sizes and specifications produced by MYZR can be connected, LVDS0 interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation, better performance and connectivity.
pin & signal definition as below:
(pin) | (signal) | (description) | (pin) | (signal) | (description) |
J20-1 | LVDS0_TX1_N | LVDS0 differential data 1) | J20-21 | TOUCH_SCL | I2C clock |
J20-2 | LVDS0_TX1_P | J20-22 | TOUCH_SDA | I2C data | |
J20-3 | GND | digital ground | J20-23 | GND | digital ground |
J20-4 | LVDS0_TX0_P | LVDS0 differential data 0 ) | J20-24 | ||
J20-5 | LVDS0_TX0_N | J20-25 | |||
J20-6 | GND | digital ground | J20-26 | 5VIN | 5V input |
J20-7 | LVDS0_TX3_N | LVDS0 differential data 3 | J20-27 | ||
J20-8 | LVDS0_TX3_P | J20-28 | |||
J20-9 | GND | digital ground | J20-29 | ||
J20-10 | LVDS0_TX2_P | LVDS0 differential data 2 ) | J20-30 | ||
J20-11 | LVDS0_TX2_N | J20-31 | NC | dangling | |
J20-12 | GND | digital ground | J20-32 | ||
J20-13 | LVDS0_CLK_N | LVDS0 differential clock | J20-33 | ||
J20-14 | LVDS0_CLK_P | J20-34 | |||
J20-15 | GND | digital ground | J20-35 | ||
J20-16 | SD1_DAT1/TOUCH_nEINT1 | GPIO control | J20-36 | ||
J20-17 | NANDF_CS3 | J20-37 | |||
J20-18 | GND | digital ground | J20-38 | ||
J20-19 | DISP0_CONTRAST | LVDS0 backlight adjustment | J20-39 | ||
J20-20 | GND | digital ground | J20-40 |
silk screen:J21
RGB crystal liquid is 24bit mode,compatible to 18bit/16bit mode,through which RGB resistance screen panel and RGB capacitor screen panel in different sizes and specifications produced by MYZR can be connected,RGB interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation,better performance and connectivity.
pin | signal | description | pin | signal | description |
J21-1 | DISP0_DAT4 | LCD data 4 | J21-21 | DISP0_DRDY | LCD_DataEn |
J21-2 | DISP0_DAT10 | LCD data 10 | J21-22 | DISP0_DAT1 | LCD data 1 |
J21-3 | DISP0_DAT2 | LCD data 2 | J21-23 | DISP0_DAT3 | LCD data 3 |
J21-4 | DISP0_DAT21 | LCD data 21 | J21-24 | DISP0_DAT8 | LCD data 8 |
J21-5 | DISP0_DAT6 | LCD data 6 | J21-25 | DISP0_DAT13 | LCD data 13 |
J21-6 | DISP0_DAT20 | LCD data 20 | J21-26 | DISP0_DAT15 | LCD data 15 |
J21-7 | DISP0_DAT19 | LCD data 19 | J21-27 | DISP0_DAT11 | LCD data 11 |
J21-8 | DISP0_HSYNCH | LCD row clock | J21-28 | DISP0_DAT23 | LCD data 23 |
J21-9 | DISP0_DAT0 | LCD data 0 | J21-29 | DISP0_DAT16 | LCD data 16 |
J21-10 | DISP0_DAT7 | LCD data 7 | J21-30 | NANDF_CS3 | GPIO control |
J21-11 | DISP0_DAT5 | LCD data 5) | J21-31 | SD1_DAT1/TOUCH_nEINT1 | |
J21-12 | DISP0_DAT12 | LCD data 12 | J21-32 | TOUCH_SCL | I2C clock |
J21-13 | DISP0_DAT9 | LCD data 9 | J21-33 | TOUCH_SDA | I2C data |
J21-14 | DISP0_DAT17 | LCD data 17 | J21-34 | 5VIN | 5V input |
J21-15 | DISP0_DAT14 | LCD data 14 | J21-35 | ||
J21-16 | DISP0_DAT22 | LCD data 22 | J21-36 | ||
J21-17 | DISP0_DAT18 | LCD data 18 | J21-37 | GND | digital ground |
J21-18 | DISP0_CLK | LCD dot clock | J21-38 | ||
J21-19 | DISP0_CONTRAST | LCD backlight adjustment | J21-39 | ||
J21-20 | DISP0_VSYNCH | LCD frame clock | J21-40 |
silk screen:J22
LVDS1 crystal liquid interface is the same as LVDS0 in terms of definition and connector model,users can connect crytal liquid in LVDS0 directly to LVDS1.
pin & signal definition:
J22-1 | LVDS1_TX1_N | LVDS1 differential data 1 | J22-21 | TOUCH_SCL | I2C clock |
J22-2 | LVDS1_TX1_P | J22-22 | TOUCH_SDA | I2C clock | |
J22-3 | GND | digital ground | J22-23 | GND | digital ground |
J22-4 | LVDS1_TX1_P | LVDS1 differential data 1 | J22-24 | ||
J22-5 | LVDS1_TX1_N | J22-25 | |||
J22-6 | GND | digital ground | J22-26 | 5VIN | 5V input |
J22-7 | LVDS1_TX3_N | LVDS1 differential data 3 | J22-27 | ||
J22-8 | LVDS1_TX3_P | J22-28 | |||
J22-9 | GND | digital ground | J22-29 | ||
J22-10 | LVDS1_TX2_P | LVDS1 differential data 2 | J22-30 | ||
J22-11 | LVDS1_TX2_N | J22-31 | NC | dangling | |
J22-12 | GND | digital ground | J22-32 | ||
J22-13 | LVDS1_CLK_N | LVDS1 difference clock | J22-33 | ||
J22-14 | LVDS1_CLK_P | J22-34 | |||
J22-15 | GND | digital ground | J22-35 | ||
J22-16 | SD1_DAT1/TOUCH_nEINT1 | GPIO control | J22-36 | ||
J22-17 | NANDF_CS3 | J22-37 | |||
J22-18 | GND | digital ground | J22-38 | ||
J22-19 | DISP1_CONTRAST | LVDS1 backlight adjustment | J22-39 | ||
J22-20 | GND | digital ground | J22-40 |
silk screen:J23
J23-1 | GND | digital ground | J23-2 | 5VIN | 5V input |
J23-3 | GND | digital ground | J23-4 | GEN_3V3 | 3.3V input |
J23-5 | I2C1_SCL | I2C1 clock | J23-6 | I2C1_SDA | I2C1 data |
J23-7 | I2C2_SCL | I2C2 clock | J23-8 | I2C2_SDA | I2C2 data |
J23-9 | I2C3_SCL | I2C3 clock | J23-10 | I2C3_SDA | I2C3 data |
J23-11 | USB_H1_PWR_EN | GPIO | J23-12 | USB_H1_OC | GPIO |
slik screen J24
J24-1 | 5VIN | 5V input | J24-2 | 5VIN | 5V input |
J24-3 | GND | digital ground | J24-4 | TOUCH_SDA | I2C3 data |
J24-5 | TOUCH_SCL | I2C3 clock | J24-6 | DISP0_CNTRST | backlight enabling |
J24-7 | GPIO6_7 | GPIO | J24-8 | GPIO2_1 | GPIO |
J24-9 | LVDS1_TX1_N | LVDS1 differential data1 | J24-10 | LVDS1_TX1_P | LVDS1 differential data1 |
J24-11 | LVDS1_TX0_P | LVDS1 differential data 0 | J24-12 | LVDS1_TX0_N | LVDS1 differential data 0 |
J24-13 | LVDS1_TX3_N | LVDS1 differential data 3 | J24-14 | LVDS1_TX3_P | LVDS1 differential data 3 |
J24-15 | LVDS1_TX2_P | LVDS1 differential data 2 | J24-16 | LVDS1_TX2_N | LVDS1 differential data 2 |
J24-17 | LVDS1_CLK_N | LVDS1 differential clock | J24-18 | LVDS1_CLK_P | LVDS1 differential clock |
J24-19 | GND | digital ground | J24-20 | GND | digital ground |
silk screen:E2
interface property:antenna pedestal
silk screen:P3
interface property:UART0,232 electrical Level, debug serial port
silk screen:J14
interface property):audio signal input, 3.5mm interface)
pin | signal | description | pin | pin | description |
J12-1 | 5VIN | 5V input | J12-2 | 5VIN | 5V input |
J12-3 | GND | digital ground | J12-4 | GND | digital ground |
J12-5 | GEN_3V3 | 3.3v input | J12-6 | GEN_3V3 | 3.3v input |
J12-7 | UART2_CTS | serial port 2 CTS | J12-8 | UART2_RTS | serial port 2 RTS |
J12-9 | UART2_RXD | serial port 2 receiving | J12-10 | UART2_TXD | serial port 2 sending |
J12-11 | UART3_RTS | serial port 3 RTS | J12-12 | UART3_RXD | serial port 3 receiving |
J12-13 | UART3_TXD | serial port 3 sending | J12-14 | UART3_CTS | serial port 3 sending |
J12-15 | UART4_TXD | serial port 4 sending | J12-16 | UART5_RXD | serial port 5 receiving |
J12-17 | UART4_RXD | serial port 4 receiving | J12-18 | UART5_TXD | serial port 5 sending |
J12-19 | GND | digital ground | J12-20 | GND | digital ground |
silk screen:P2
interface property:UART4, RS-232, application serial port
silk screen:J11
interface property:UART3, RS-485, application serial port
silk screen:U12
interface property: GigE Vision)
silk screen:J9
interface property:3Gbps SATA I interface
silk screen:J10
J10-1 | 5VIN | 5V power input |
J10-2 | GND | digital ground |
J10-3 | GND | digital ground |
J10-4 | NC | unconnected |
silk screen:J7
pin&signal definition:
J7-1 | 5VIN | 5V input | J7-2 | 5VIN | 5V input |
J7-3 | 5VIN | 5V input | J7-4 | GND | digital ground |
J7-5 | CSI_CLK0P | CSI differential clock | J7-6 | CSI_CLK0M | CSI differential clock |
J7-7 | GND | digital ground | J7-8 | CSI_D0P | CSI differential data 0 |
J7-9 | CSI_D0M | CSI differential data 0 | J7-10 | GND | digital ground |
J7-11 | CSI_D1P | CSI differential data 1 | J7-12 | CSI_D1M | CSI differential data 1 |
J7-13 | GND | digital ground | J7-14 | CSI_MCLK | CSI master clock |
J7-15 | GND | digital ground | J7-16 | GND | digital ground |
J7-17 | CSI2-SDA | I2C2 data | J7-18 | CSI2_SCL | I2C2 clock |
J7-19 | GPIO7_12 | GPIO | J7-20 | GPIO7_13 | GPIO |
silk screen:J5
interface property:USB ON-The-Go, use for burning
silk screen:P1
interface property: Hundred megabytes Ethernet USB1 extension
silk screen:J2
interface property):USB1 expansion, double USB
silk screen:U8
interface property:I2C communication RTC
silk screen:U1
Preselection screen type:N070ICN-GB1
pin | signal | description | pin | signal | 描述 (description) |
U1-1 | GND1 | digital ground | U1-17 | LEDPWM | (unconnected |
U1-2 | GND2 | digital ground | U1-18 | CLK_P | DSI differential clock |
U1-3 | GND3 | digital ground | U1-19 | VLED1 | 9V backlight power supply input |
U1-4 | D0_N | DSI differential data | U1-20 | GND6 | digital ground |
U1-5 | RST | reset | U1-21 | VLED2 | 9V backlight power supply input |
U1-6 | D0_P | DSI differential data 0 | U1-22 | D2_N | unconnected |
U1-7 | VCI1_3V3 | 3.3V input | U1-23 | ID | earthing |
U1-8 | GND4 | digital ground | U1-24 | D2_P | unconnected |
U1-9 | VCI2_3V3 | 3.3V input | U1-25 | LED1 | earthing |
U1-10 | D1_N | DSI differential data 1 | U1-26 | GND7 | digital ground |
U1-11 | MTP | unconnected | U1-27 | LED2 | unconnected |
U1-12 | D1_P | DSI differential data 1 | U1-28 | D3_N | unconnected |
U1-13 | VDDI2_1V8 | 1.8V input | U1-29 | GND8 | digital ground |
U1-14 | GND5 | digital ground | U1-30 | D3_P | unconnected |
U1-15 | VDDI2_1V8 | 1.8V input | U1-31 | GND9 | digital ground |
U1-16 | CLK_N | DSI differential clock |
silk screen:J1
interface property: 9V power supply input)
silk screen:J3
interface property:power switch
silk screen:J4
interface property:
jack with inside positive and outside negative
power supply:5V
current:2.5A or above
silk screen:J6
interface property:HDMI-1.4
silk screen:J8
interface property:miniPCIE standard interface
silk screen:U11
U11-1 | JTAG_TDK | TCK input | U11-2 | GND | digital ground |
U11-3 | JTAG_TDO | test data output | U11-4 | VCC | 3.3V input |
U11-5 | JTAG_TMS | test mode selection | U11-6 | nRST | reset |
U11-7 | NC | unconnected | U11-8 | NC | unconnected |
U11-9 | JTAG_TDI | test mode selection | U11-10 | GND | digital ground |
silk screen:J8
interface property: 3G SIM card
silk screen:U14
U14-1 | 5VIN | 5V input | U14-2 | GEN_3V3 | 3.3V input |
U14-3 | SD3_DATA4 | configurable as GPIO | U14-4 | SD3_DATA5 | configurable as GPIO |
U14-5 | SD3_DATA7 | configurable as GPIO | U14-6 | SD3_DATA6 | configurable as GPIO |
U14-7 | GPIO6_16 | GPIO | U14-8 | GPIO2_7 | GPIO |
U14-9 | GPIO2_3 | GPIO | U14-10 | GPIO2_6 | GPIO |
U14-11 | GPIO6_9 | GPIO | U14-12 | GPIO6_11 | GPIO |
U14-13 | GPIO2_2 | GPIO | U14-14 | GPIO2_0 | GPIO |
U14-15 | GPIO2_4 | GPIO | U14-16 | GPIO2_5 | GPIO |
U14-17 | GPIO1_29 | GPIO | U14-18 | GPIO1_27 | GPIO |
U14-19 | GPIO1_30 | GPIO | U14-20 | GPIO1_26 | GPIO |
U14-21 | GPIO1_24 | GPIO | U14-22 | GND | 数字地(digital ground) |
U14-23 | SD2_CLK | SD2 clock | U14-24 | SD2_DATA0 | SD2 data wire |
U14-25 | SD2_DATA3 | SD2 data wire | U14-26 | SD2_DATA2 | SD2 data wire |
U14-27 | SD2_CMD | SD2 command pin | U14-28 | SD2_DATA1 | SD2 data wire |
U14-29 | USB_OTG_OC | configurable as GPIO | U14-30 | USB_OTG_PWR_EN | configurable as GPIO |
U14-31 | GND | digital ground | U14-32 | GND | digital ground |
U14-33 | SD1_CMD | SD1 command pin | U14-34 | SD1_DAT0 | SD1 data wire |
U14-35 | SD1_CLK | SD1 clock | U14-36 | SD1_DAT1 | SD1 data wire |
U14-37 | SD1_DAT3 | SD1 data wire | U14-38 | SD1_DAT2 | SD1 data wire |
U14-39 | GND | digital ground | U14-40 | GND | digital ground |
silk screen:J7
pin | signal | description | pin | digital ground | description |
silk screen:J15
interface property:CAN2
silk screen:J17
interface property):CAN1
interface property:J19
J19-1 | 5VIN | 5V input | J19-2 | GND | digital ground |
J19-3 | CSI0_SCL | I2C1 clock | J19-4 | CSI0_SDA | I2C1 data |
J19-5 | CSI0_VSYNCH | field synchronization interface | J19-6 | CSI0_HSYNCH | Line synchronization interface |
J19-7 | CDI0_PIXCLK | camera output master clock | J19-8 | CSI0_MCLK | CSI output master clock |
J19-9 | CSI0_DAT19 | CSI data bus | J19-10 | CSI0_DAT18 | CSI data bus |
J19-11 | CSI0_DAT17 | CSI data bus | J19-12 | CSI0_DAT16 | CSI data bus |
J19-13 | CSI0_DAT15 | CSI data bus | J19-14 | CSI0_DAT14 | CSI data bus |
J19-15 | CSI0_DAT13 | CSI data bus | J19-16 | CSI0_DAT12 | CSI data bus |
J19-17 | GND | digital ground | J19-18 | CSI0_DATA_EN | bus enable |
J19-19 | NC | unconnected | J19-20 | NC | unconnected |
silk screen:J25
interface property: standard SD cassette
silk screen:J26
J26-1 | PCIE_RXP | receiving differential signal | J26-13 | GPIO6_8 | GPIO |
J26-2 | PCIE_RXM | receiving differential signal | J26-14 | GPIO6_14 | GPIO |
J26-3 | GND | digital ground | J26-15 | PCIE_SMD_CLK | I2C3 clock |
J26-4 | PCIE_TXP | sending differential signal | J26-16 | PCIE_SMB_DATA | I2C3 data |
J26-5 | PCIE_TXM | sending differential signal | J26-17 | GPIO7_11 | GPIO |
J26-6 | GND | digital ground | J26-18 | GND | digital ground |
J26-7 | CLK1_P | differential clock | J26-19 | GND | digital ground |
J26-8 | CLK1_N | differential clock | J26-20 | GND | digital ground |
J26-9 | GND | digital ground | J26-21 | 5VIN | 5V input |
J26-10 | 3G_USBDM | USB differential signal | J26-22 | 5VIN | 5V input |
J26-11 | 3G_USBDP | USB differential signal | J26-23 | 5VIN | 5V input |
J26-12 | GND | digital ground | J26-24 | 5VIN | 5V input |
silk screen:U24
module model:UM12BS
silk screen:U27
module model:NEO-6M
silk screen:J27
J27-1 | 5VIN | 5V input | J27-17 | EIM_DA12 | address & data |
J27-2 | 5VIN | 5V input | J27-18 | EIM_CS0 | chip select 0 |
J27-3 | 5VIN | 5V input | J27-19 | EIM_CS1 | chip select 1 |
J27-4 | EIM_DA0 | address & data | J27-20 | EIM_LBA |
J27-5 | EIM_DA9 | address & data | J27-21 | EIM_EB1 |
J27-6 | EIM_DA5 | address & data | J27-22 | EIM_DA4 | address & data |
J27-7 | EIM_BCLK | output clock | J27-23 | EIM_EB0 |
J27-8 | EIM_DA13 | address & data | J27-24 | EIM_DA10 | address & data |
J27-9 | EIM_DA14 | address & data | J27-25 | EIM_DA2 | address & data |
J27-10 | EIM_OE |
| J27-26 | EIM_EW |
J27-11 | EIM_DA11 | address & data | J27-27 | EIM_WAIT |
J27-12 | EIM_DA1 | address & data | J27-28 | EIM_DA15 | address & data |
J27-13 | EIM_DA6 | address & data | J27-29 | GND | digital ground |
J27-14 | EIM_DA3 | address & data | J27-30 | GND | digital ground |
J27-15 | EIM_DA8 | address & data | J27-31 | GND | digital ground |
J27-16 | EIM_DA7 | address & data | J27-32 | GND | digital ground |
If you would like to know more about our products, please visit www.myzr.com.cn or email to enquiry@myzr.com.cn.
